Freescale MQX™ 4.1 for TWR-K64F120M Release
Document created by Enrique Ochoa Vazquez Employee on Mar 19, 2014
Version 1Show Document
  • View in full screen mode
The new Freescale MQX™ 4.1 for TWR-K64F120M release is now available on the www.freescale.com
·         Files available
Name
Description
1
FSL_MQX_TWRK64F120M_RELEASE_NOTES
Freescale   MQX™ RTOS 4.1.0 TWR-K64F120M Release Notes
2
Freescale   MQX RTOS 4.1.0 for the TWRK64F120M
Includes   an RTOS, File System, TCP/IP and USB host/device software stacks. Does not   require MQX™ 4.1 installation.
·         Target HW board
o   TWR-K64F120M
·         New features
o   PSP support for the K64F120M Microcontroller
o   BSP for the TWR-K64F120M tower system module
o   Standard set of I/O drivers supporting the K64F120M peripherals including:
§  LWGPI/O driver
§  Serial interrupt and polled driver
§  DMI SPI driver
§  I2C interrupt and polled driver
§  ADC
§  LWADC
§  Flash Driver
§  RTC Driver
§  PIT Timer
§  LPT Timer
§  SD card driver
§  SDHC
§  FlexCAN
§  SAI
§  ENET
o   USB Host and Device drivers and stacks
o   Example and demo applications demonstrating MQX, USB, RTCS, and MFS usage
o   RTCS TCP/IP stack
o   MFS file system
o   Shell command line interface
·         Known issues
o   For known issues and limitations please consult the release notes.
    Outcomes
