The drive signal cannot detect the sai3 signal of imx8mm
CheLL
When using tinyplay to play wav files, wav is 48k 32-bit wide and single channel. But the driver does not detect the i2s signal, how should I debug?
Hi CheLL
one can try to identify problem with amixer, described in sect.7.5 Audio Mixer (AUDMIX)
i.MX Linux Reference Manual​
https://source.codeaurora.org/external/imx/imx-test/tree/test/mxc_amix_test?h=imx_5.4.24_2.1.0
