max frequency on MPC5777C
marcellobellini
I would need to increase the frequency of the mpc5777c from 300mhz to 324mhz. My application works in a temperature range of 0-70 degrees.
it's possible?
marcellobellini
OK i try, because i have no other solution to speed up a function
petervlna
The max tested and specified frequency for this device is 300MHz. If you run it at higher we will not guarantee its correct operation as specified in datasheet.
Peter
