hi,
We are trying to migrate the application code written for MPC5674F on CodeWarrior Power PC compiler to GCC compiler with S32DS IDE.
We were able to successfully compile the code with GCC compiler, but when compiled with GCC compiler the FLASH memory occupied has increased by 300%.
Can you please guide us what could be the reason for so much increase in memory usage any hints to analyze would help us understand the root cause and we can try to minimize the memory footprint with GCC compiler which according to us should be same as per codewarrior compiler.
thanks,
Nagesh
sorry for delay. What optimization type are you using? You can try -Os.
