MCUXpresso Config Tools v7 Now Available
petrstruzka
We are pleased to announce that MCUXpresso Config Tools v7 are now available.
MCUXpresso Configuration Tools is a product with set of tools that help users of all levels with a Cortex-M-based MCU solution.
Features
  • Available as Web, Desktop application and MCUXpresso IDE plug-ins
  • MCUXpresso SDK v2 support
  • Multicore support
  • GUI localized for English and Simplified Chinese
  • On-Demand device data download for latest features and support
  • Integrated directly within MCUXpresso IDE, standalone version supports other compilers and IDEs
  • Currently there are the following tools available:
Downloads
Revision History
7.0.1
  • Mac OS X 10.15 operating system support added.
  • TEE tool: Displays correctly inaccessible regions in "Memory attribution map" view.7.0
7.0
  • Added "Help | Kit/Board Information" option that displays information about currently used kit or board.
  • Clickable Part number, Board and Kit name supported. It displays information about currently used processor, board and kit.
  • Data Manager - supports clearing locally cached processors, boards, kit and components content.
  • Configuration Preferences - supports custom copyright in generated sources
  • TEE tool: Memory map is now interactive, cell double click opens its configuration.
  • TEE tool: Memory map now displays peripherals space details.
  • TEE tool: Added possibility to import memory configuration from MCUXpresso IDE project(s).
  • TEE tool: Memory regions in Access overview are now grouped by memory type; all memory region aliases are displayed in a single row.
  • TEE tool: Pins table now contains pin labels from the Pins tool.
  • TEE tool: Additional validations and security setting recommendations.
  • Peripherals tool: Tool can now generate binary output files.
  • Peripherals tool: Component name is derived from the selected peripheral by default. It can be overwritten by a user.
  • Peripherals tool: Documentation view improvements related to navigation added two new features - header with links in documentation content and selection box in header of view.
  • Peripherals tool: Deprecated components have "(deprecated)" suffix in the add component dialog if there are still other instances of this type in configuration.
  • Pins tool: Added automatic routing feature which can be used for conflict resolution in the current functional group.
  • (MCUXpresso Config Tools only): Preferences - Added Dark theme support
  • (MCUXpresso IDE only): Added SEMC/SDRAM stress tests, with RT support.
  • (MCUXpresso IDE only): Added FlexSPI/NOR Validation tool, with RT support.
Community
MCUXpresso Config Tools Data
The Data for MCUXpresso Config Tools v7 was successfully deployed on the production system.
What’s new in data
The Data for MCUXpresso Config Tools v7 release provides following updates:
  • 330 Kinetis, LPC and i.MX processors and 229 boards supported in total.
  • Updated code generated by Pins, Clocks and Peripherals tool to support SDK v2.7 API.
  • Peripherals tool support added for LPC8N04, KV11/4x/5x, KExx, KV3x and K22 (FN1M0 and FX512 memory variants only) processors. 200 processors supported by Peripherals tool in total - all processors in SDK v2.7 are supported by Peripherals tool now.
  • Added 21 new Peripherals tool components for various Kinetis, LPC and i.MX RT processors. 103 components are available now in total.
  • Improved DMA support in Peripherals tool - edma and lpc_dma components updated to support transactional and non-transactional modes, improved support of DMA request settings in other Peripherals tool components.
  • Improved interrupt settings in Peripherals tool components, added default interrupt subroutine snippets.
  • Added new Audio 1.0 and Device Firmware Update classes to USB Peripherals tool component, supported suspend/resume/remote wake-up feature, improved PHDC class support and USB endpoint settings.
  • Added support of Memory validation for i.MX8MM processors, maintenance update of Memory validation/DDR tool supporting RT1020, RT1050, RT1060, RT1064 and i.MX8MM processors.
  • Updated TEE tool for LPC55S6x processors.
  • Various other small improvements and bug fixes of Pins, Clocks and Peripherals tool.
Supported processors, boards, kits and components
i.MX
Kinetis
LPC
QN
imx7ulp-14x14-arm2
imx7ulp-evk
imx7ulp-evk-emmc
imx7ulp-evk-emmc-qspi
imx7ulp-evk-ft5416
imx7ulp-evk-lpuart
imx7ulp-evk-mipi
imx7ulp-evk-qspi
imx7ulp-evk-sd1
imx7ulp-evk-sensors-to-i2c5
imx7ulp-evk-wm8960
IMXRT1050-EVKB
MCIMX7ULP-EVK-REV-B
MIMX8M-EVK-REV-B
MIMX8MM-EVK-REV-C
MIMX8MN-EVK-REV-A
MIMX8QM-MEK-REV-B
MIMX8QX-MEK-REV-B
MIMXRT1010-EVK
MIMXRT1015-EVK
MIMXRT1020-EVK
MIMXRT1060-EVK
MIMXRT1064-EVK
FRDM-K32L3A6
FRDM-K32L2B
FRDM-K22F
FRDM-K28F
FRDM-K28FA
FRDM-K64F
FRDM-K66F
FRDM-K82F
FRDM-KE02Z40M
FRDM-KE04Z
FRDM-KE06Z
FRDM-KE15Z
FRDM-KE16Z
FRDM-KL02Z
FRDM-KL03Z
FRDM-KL25Z
FRDM-KL26Z
FRDM-KL27Z
FRDM-KL28Z
FRDM-KL43Z
FRDM-KL46Z
FRDM-KL82Z
FRDM-KV10Z
TWR-KV58F220M
TWR-KW24D512
USB-KW24D512
USB-KW41Z
FRDM-KV11Z
FRDM-KV31F
FRDM-KW24
FRDM-KW36
FRDM-KW41Z
HEXIWEAR
HVP-KE18F
HVP-KV11Z75M
HVP-KV31F120M
HVP-KV46F150M
HVP-KV58F
MAPS-KS22
TWR-K21D50M
TWR-K21F120M
TWR-K22F120M
TWR-K24F120M
TWR-K60D100M
TWR-K64F120M
TWR-K65F180M
TWR-K80F150M
TWR-KE18F
TWR-KL28Z72M
TWR-KL43Z48M
TWR-KL82Z72M
TWR-KM34Z75M
TWR-KV10Z32
TWR-KV11Z75M
TWR-KV31F120M
TWR-KV46F150M
LPC54018-IoT-Module
LPC54S018-IoT-Module
LPC8N04DevBoard
LPCXpresso51U68
LPCXpresso54018
LPCXpresso54018M
LPCXpresso54102
LPCXpresso54114
LPCXpresso54608
LPCXpresso54618
LPCXpresso54628
LPCXpresso54S018
LPCXpresso54S018M
LPCXpresso802
LPCXpresso804
LPCXpresso812
LPCXpresso824
LPCXpresso845
LPC845BREAKOUT
LPCXpresso55S28
LPCXpresso55S69
QN908XCDK
Processors:
i.MX
Kinetis
LPC
MCIMX7U3xxxxx
MCIMX7U5xxxxx
MIMX8MD6xxxHZ
MIMX8MD6xxxJZ
MIMX8MD7xxxHZ
MIMX8MD7xxxJZ
MIMX8MM1xxxKZ
MIMX8MM1xxxLZ
MIMX8MM2xxxKZ
MIMX8MM2xxxLZ
MIMX8MM3xxxKZ
MIMX8MM3xxxLZ
MIMX8MM4xxxKZ
MIMX8MM4xxxLZ
MIMX8MM5xxxKZ
MIMX8MM5xxxLZ
MIMX8MM6xxxKZ
MIMX8MM6xxxLZ
MIMX8MN1xxxIZ
MIMX8MN1xxxJZ
MIMX8MN2xxxIZ
MIMX8MN2xxxJZ
MIMX8MN3xxxIZ
MIMX8MN3xxxJZ
MIMX8MN4xxxIZ
MIMX8MN4xxxJZ
MIMX8MN5xxxIZ
MIMX8MN5xxxJZ
MIMX8MN6xxxIZ
MIMX8MN6xxxJZ
MIMX8MQ5xxxHZ
MIMX8MQ5xxxJZ
MIMX8MQ6xxxHZ
MIMX8MQ6xxxJZ
MIMX8MQ7xxxHZ
MIMX8MQ7xxxJZ
MIMX8QM6xxxFF
MIMX8QX2xxxFZ
MIMX8QX6xxxFZ
MIMXRT1011xxxxx
MIMXRT1015xxxxx
MIMXRT1021xxxxx
MIMXRT1051xxxxB
MIMXRT1052xxxxB
MIMXRT1061xxxxA
MIMXRT1062xxxxA
MIMXRT1064xxxxA
K32L3A60xxx
K32L2B11xxxxA
K32L2B21xxxxA
K32L2B31xxxxA
MK02FN128xxx10
MK02FN64xxx10
MK10DN512xxx10
MK10DX128xxx10
MK10DX256xxx10
MK11DN512Axxx5
MK11DN512xxx5
MK11DX128Axxx5
MK11DX128xxx5
MK11DX256Axxx5
MK11DX256xxx5
MK12DN512xxx5
MK12DX128xxx5
MK12DX256xxx5
MK20DN512xxx10
MK20DX128xxx10
MK20DX256xxx10
MK21DN512Axxx5
MK21DN512xxx5
MK21DX128Axxx5
MK21DX128xxx5
MK21DX256Axxx5
MK21DX256xxx5
MK21FN1M0Axxx12
MK21FN1M0xxx12
MK21FX512Axxx12
MK21FX512xxx12
MK22DN512xxx5
MK22DX128xxx5
MK22DX256xxx5
MK22FN128xxx10
MK22FN128xxx12
MK22FN1M0Axxx12
MK22FN1M0xxx12
MK22FN256xxx12
MK22FN512xxx12
MK22FX512Axxx12
MK22FX512xxx12
MK24FN1M0xxx12
MK24FN256xxx12
MK26FN2M0xxx18
MK27FN2M0Axxx15
MK27FN2M0xxx15
MK28FN2M0Axxx15
MK28FN2M0xxx15
MK30DN512xxx10
MK30DX128xxx10
MK30DX256xxx10
MK40DN512xxx10
MK40DX128xxx10
MK40DX256xxx10
MK50DN512xxx10
MK50DX256xxx10
MK51DN256xxx10
MK51DN512xxx10
MK51DX256xxx10
MK52DN512xxx10
MK53DN512xxx10
MK53DX256xxx10
MK60DN256xxx10
MK60DN512xxx10
MK60DX256xxx10
MK63FN1M0xxx12
MK64FN1M0xxx12
MK64FX512xxx12
MK65FN2M0xxx18
MK65FX1M0xxx18
MK66FN2M0xxx18
MK66FX1M0xxx18
MK80FN256xxx15
MK82FN256xxx15
MKE02Z16xxx4
MKE02Z32xxx4
MKE02Z64xxx4
MKE04Z128xxx4
MKE04Z64xxx4
MKE04Z8xxx4
MKE06Z128xxx4
MKE06Z64xxx4
MKE14F256xxx16
MKE14F512xxx16
MKE14Z128xxx7
MKE14Z256xxx7
MKE14Z32xxx4
MKE14Z64xxx4
MKE15Z128xxx7
MKE15Z256xxx7
MKE15Z32xxx4
MKE15Z64xxx4
MKE16F256xxx16
MKE16F512xxx16
MKE16Z32xxx4
MKE16Z64xxx4
MKE18F256xxx16
MKE18F512xxx16
MKL02Z16xxx4
MKL02Z32xxx4
MKL02Z8xxx4
MKL03Z16xxx4
MKL03Z32xxx4
MKL03Z8xxx4
MKL13Z32xxx4
MKL13Z64xxx4
MKL14Z32xxx4
MKL14Z64xxx4
MKL15Z128xxx4
MKL15Z32xxx4
MKL15Z64xxx4
MKL16Z128xxx4
MKL16Z256xxx4
MKL16Z32xxx4
MKL16Z64xxx4
MKL17Z128xxx4
MKL17Z256xxx4
MKL17Z32xxx4
MKL17Z64xxx4
MKL24Z32xxx4
MKL24Z64xxx4
MKL25Z128xxx4
MKL25Z32xxx4
MKL25Z64xxx4
MKL26Z128xxx4
MKL26Z256xxx4
MKL26Z32xxx4
MKL26Z64xxx4
MKL27Z128xxx4
MKL27Z256xxx4
MKL27Z32xxx4
MKL27Z64xxx4
MKL28Z512xxx7
MKL33Z128xxx4
MKL33Z256xxx4
MKL33Z32xxx4
MKL33Z64xxx4
MKL34Z64xxx4
MKL36Z128xxx4
MKL36Z256xxx4
MKL36Z64xxx4
MKL43Z128xxx4
MKL43Z256xxx4
MKL46Z128xxx4
MKL46Z256xxx4
MKL82Z128xxx7
MKM34Z256xxx7
MKS20FN128xxx12
MKS20FN256xxx12
MKS22FN128xxx12
MKS22FN256xxx12
MKV10Z128xxx7
MKV10Z16xxx7
MKV10Z32xxx7
MKV10Z64xxx7
MKV11Z128xxx7
MKV11Z64xxx7
MKV30F128xxx10
MKV30F64xxx10
MKV31F128xxx10
MKV31F256xxx12
MKV31F512xxx12
MKV42F128xxx16
MKV42F256xxx16
MKV42F64xxx16
MKV44F128xxx16
MKV44F256xxx16
MKV44F64xxx16
MKV46F128xxx16
MKV46F256xxx16
MKV56F1M0xxx24
MKV56F512xxx24
MKV58F1M0xxx24
MKV58F512xxx24
MKW21D256xxx5
MKW21D512xxx5
MKW21Z256xxx4
MKW21Z512xxx4
MKW22D512xxx5
MKW24D512xxx5
MKW31Z256xxx4
MKW31Z512xxx4
MKW35A512xxx4
MKW35Z512xxx4
MKW36A512xxx4
MKW36Z512xxx4
MKW41Z256xxx4
MKW41Z512xxx4
LPC51U68
LPC54005
LPC54016
LPC54018
LPC54101J256
LPC54101J512
LPC54102J256
LPC54102J512
LPC54113J128
LPC54113J256
LPC54114J256
LPC54605J256
LPC54605J512
LPC54606J256
LPC54606J512
LPC54607J256
LPC54607J512
LPC54608J512
LPC54616J256
LPC54616J512
LPC54618J512
LPC54628J512
LPC54S005
LPC54S016
LPC54S018
LPC54018M
LPC54S018M
LPC802
LPC804
LPC810
LPC811
LPC812
LPC822
LPC824
LPC832
LPC834
LPC844
LPC845
LPC8N04
LPC5526
LPC5528
LPC55S26
LPC55S28
LPC55S66
LPC55S69
QN
QN908XC
Components:
Components
acmp
adc12
adc16
adc_12b1msps_sar
adc_etc
aoi
capt
cmp_1
cmp
cmt
cop
crc
csi
ctimer
dac
dcp
dma
dmic
dspi
edma
eeprom
elcdif
enc
ewm
flexbus
flexcan
flexcomm_i2c
flexcomm_i2s
flexcomm_spi
flexcomm_usart
flexio_i2c_master
flexio_i2s
flexio_spi
flexio_uart
flexspi
ftm
gint
gpio
gpt
hashcrypt
i2c
igpio
kpp
llwu
lpadc
lpc_acomp
lpc_adc
lpc_crc
lpc_dac
lpc_dma
lpc_gpio_1
lpc_gpio
lpc_i2c_1
lpc_i2c
lpc_lcdc
lpc_minispi
lpc_miniusart
lpc_rtc_1
lpc_rtc
lpc_spi_ssp
lpi2c
lpit
lpsci
lpspi
lptmr
lpuart
mcan
mrt
msg
nfc
ostimer
pdb
pint
pit
plu
pwm
qtmr
rit
rnga
rtc
rtwdog
sai
sctimer
semc
sha
snvs_hp
snvs_lp
spdif
spi
system
tempmon
tpm
trng
tsens
uart
usb
utick
vref
vspi
vusart
wdog01
wdog32
wdog
wdt
wkt
wwdt
